Emergency: How do I make segments stay connected to each other while Extruding?
COW Forums : Maxon Cinema 4D
Bernard Santos
on Jul 6, 2016 at 1:48:52 am
Hi everyone,
I'm still pretty new to 3D modelling with C4D, and I've seen this fixed before, I just can't remember what to do first before I extrude. The piece I'm working on is about done, but it is due on Friday, and this base is the only thing I need left to do.
It would be great to get it figured out asap.
Thanks a bunch in advance everyone!!
10268_capture32.png.zip
Brian Jones
Re: Emergency: How do I make segments stay connected to each other while Extruding?
on Jul 6, 2016 at 3:55:44 am
make sure Preserve Groups is checked in the Extrude Options
Bernard Santos
on Jul 6, 2016 at 4:20:06 am
That's thing, it is.
Even tried it with another Premitive with a few subdivisions added, same issue.
Thanks for the tip though.
Brian Jones
on Jul 6, 2016 at 4:29:41 am
it works, can you post an example file where the extrude doesn't work?
Bernard Santos
on Jul 6, 2016 at 4:59:49 am
Here you go. I made a copy so you can try it out.
10270_extrudenotworkingright.c4d.zip
Adam Trachtenberg
on Jul 6, 2016 at 12:58:52 pm
You need to set the minimum angle in the extrude tool to a positive number, like 89.
Bernard Santos
on Jul 6, 2016 at 4:50:46 pm
Hi Adam,
I've tried that as well, and it's still not connected. I need to make an Inner Extrude after the extrude, and it's creating a weird split at the corner of the top faces that are selected.
Thanks Adam!
