Add Segment to a cube after made editable
COW Forums : Maxon Cinema 4D
Joe Bodego
on Jun 3, 2016 at 2:49:41 am
Hello, i created a cube with 4 segments on each axis then made it editable, i then realize i wanted to add 2 more segments, how can i do that. Just learning this program, thanks...
Michael Goldberg
Re: Add Segment to a cube after made editable
on Jun 3, 2016 at 4:29:50 am
You can select all your polys, and select mesh/command/subdivide.
If you only want more polys in certain areas, you can use the knife tool to create more edges.
Mike
Joe Bodego
on Jun 5, 2016 at 8:37:40 am
Thank you so much for this, it was a little touchy bu i got it by setting the knife to "Loop"
