Eliminating leading decimal point in xpresso?
COW Forums : Maxon Cinema 4D
Brian Fo
on May 9, 2016 at 10:02:51 pm
I have a expresso controlled pie chart that animates percentages as you adjust each slice.
It works fine except that when you adjust any slice size, instead of just stating "30%" it states ".30%" - Anyone know a way to remove the decimal point?
Brian Jones
Re: Eliminating leading decimal point in xpresso?
on May 9, 2016 at 11:35:39 pm
the easiest way is probably to multiply the number by 100 before you insert the value into the node
