Nubbish question Cinema 4D R16 "Tinted border"
COW Forums : Maxon Cinema 4D
Christopher Molina
on Apr 11, 2015 at 6:59:02 pm
I'm trying to get rid of these tinted lines, but having trouble. I went to Viewport settings and disable tinted borders and that didn't work. Also side note the lines show up on render view, but not render to picture viewer. The background looks infinite if I render it out its just the render preview and regular viewport that seem to show this. Any suggestions would be appreciated thank you.
Image and video hosting by TinyPic
Brian Jones
Re: Nubbish question Cinema 4D R16 "Tinted border"
on Apr 11, 2015 at 10:53:55 pm
tinted border doesn't do that, it shows what part of the viewport is going to be rendered with the current output settings. So your look must come from the setup of the scene or the texture - can't tell without seeing the file.
Christopher Molina
on Apr 12, 2015 at 5:34:31 am
Thanks for your prompt reply I figured it out, by default in R15 cinema 4D enables cycle when you chose gradient. I unchecked circular and all was solved thank you!
Here's my results :)
