mapping one texture onto a 'connect' object
COW Forums : Maxon Cinema 4D
Andrew Lyster
on Sep 25, 2014 at 10:25:35 am
I have used the connect tool to join several landscape layers, on which I am trying to texture with one large netted texture that i need to use an alpha channel on.
the problem is, when i apply the texture onto the connect layer it still segments the texture onto each landscape layer, when I want it to seamlessly map the texture over the connected object as a whole.
any help would be much appreciated!
thanks
Brian Jones
Re: mapping one texture onto a 'connect' object
on Sep 25, 2014 at 2:29:46 pm
change the material mapping from UVW to Flat probably
