Cinema 4D Mirror Selection
COW Forums : Maxon Cinema 4D
Drew Smith
on Aug 24, 2014 at 4:14:53 pm
Hi there. I'd been modeling in Maya and there was an option to mirror a selection. Basically set the plane down the center of a symmetrical modeland whenever you make a selection or soft selection the software selects the corresponding points on the other side of the model. It was great because was just working on one model- not 2 halves of a model that would need to be stuck back together and have holes patched around the seam later.
Is there any similar function in Cinema 4D? The only way I can find is to use the symmetry object and that makes it pretty time consuming to use soft selections because I end up with holes in the middle of the completed model at the end that I have to go through and fix.
Cactus Dan
Re: Cinema 4D Mirror Selection
on Aug 26, 2014 at 12:31:53 am
Howdy,
You may be interested in my CD Symmetry Tools plugin, which has the CD Symmetry Tag that allows you to work in symmetry on a single model
Adios,
Cactus Dan
Cinema 4D R13 Prime
http://www.cactus3d.com
http://www.cactus3d.com/Plugins.html
