Displacer Deformer with Tiled Textures on Single Object
COW Forums : Maxon Cinema 4D
Timothy Jansen
on Aug 5, 2014 at 5:22:09 am
Hey guys,
First time posting. I have an image that I've split into 30 tiles and are being used as separate tiled material tags on a single object. All the tiles line up perfectly, but when I use the displacer deformer the displacer only applies to the displacement of the first material tag. Is there a way to make the displacer object apply to all the texture tags on the object?
I'd like to use the displacer deformer so I can project a couple splines directly onto the surface of the object.
Any help would be great.
