Lighting Interiors
COW Forums : Maxon Cinema 4D
Jared Benson
Lighting Interiors
on Jul 14, 2014 at 2:53:55 pm
Kind of a newb here and I have a very detailed model that I am working on. I am trying to make a cross section of it, using near clipping on the camera but none of my light sources will illuminate the interior. I'm using an older model IMAC so using a boole object actually freezes C4D. Is there any way to get good lighting in the interior or a model like this when using near clipping on the camera?
Darby Edelen
Re: Lighting Interiors
on Jul 14, 2014 at 3:13:49 pm
Clipping planes on the camera do not actually remove geometry before the shading stage of rendering.
You have to modify the geometry either through a boolean operation or by cutting and removing geometry.
If the Boole generator is too slow you could try rBoole (render time boolean).
http://plugins4cinema4d.com/rboole.html
Darby Edelen
Adam Trachtenberg
on Jul 14, 2014 at 3:32:14 pm
I suggest you try the rboole plugin here: http://plugins4cinema4d.com/rboole.html
Setup is little tricky but it works well once you get the hang of it.
