How do I create like a echo trail in C4D (kind of like a superman effect)
COW Forums : Maxon Cinema 4D
Daniel Bent
on Apr 21, 2014 at 11:25:43 pm
I doing a project in Cinema 4d, How do I do create a chryon or echo trail effect in C4D? I know how to do it in AE, but can you do it in cinema 4d? Here's an example from these two images.
Brian Jones
Re: How do I create like a echo trail in C4D (kind of like a superman effect)
on Apr 22, 2014 at 4:13:01 pm
the superman effect is very easy, it's just text extruded (or you could sweep text along a spline for a shaped extrude rather than straight out in that example) with a white texture on the front face and a transparent blue on the rest.
The Buena Vista looks like the text swept on a spline kind of shape but the blurriness would be a lot easier in post, it might be possible with depth blur with real tight control (or some other method) but I don't know.
Tony Barone
on Apr 22, 2014 at 7:10:36 pm
I put together a setup that achieves what you may be going for. You can easily change the text and the extrusion length to your liking.
7388_texteffect.c4d.zip
Daniel Bent
on Apr 23, 2014 at 11:17:02 am
Okay. The Superman text works for me. Thanks for the C4D Project File. And Thank you for helping! :)
