Offset nulls to play at different times
COW Forums : Maxon Cinema 4D
Mike Tosetto
on Sep 23, 2013 at 6:04:04 am
Hi guys
I can't believe I'm stumped on this.
I have a null which holds a bunch of mograph objects that animate how I want them to.
I've duped that null 2 times so I have three nulls holding the same animation.
All I want to do is offset the timing of the nulls so one null plays, then 12 frames later then next null starts and so on.
I'm sure this must be a simple thing but I just can't work it out?
If anyone can shed some light on this I'd really appreciate it. I'm sure it must be a simple thing.
Cheers
Mike
miketosetto dot com
Adam Trachtenberg
Re: Offset nulls to play at different times
on Sep 24, 2013 at 12:03:37 am
Use the offset animation feature in a step or shader effector.
Mike Tosetto
on Sep 24, 2013 at 11:49:10 am
Thanks Adam. Ending up solving this using Legacy XRefs and offsetting the animation.
Did the trick.
miketosetto dot com
