Softbody: How to keep a falling rope's crossection constant when it collides w/ground?
COW Forums : Maxon Cinema 4D
Per Sverre Wold-Hansen
on May 10, 2013 at 3:16:24 am
I need a random coil of rope which has fallen into a heap. (Will save the fixed result as an object.)
The rope sort of "melts" when hitting the floor.
Can anyone help with the settings in the softbody tag to achieve this? - I have tried "everything"...
PerS
Dan Conrad
Re: Softbody: How to keep a falling rope's crossection constant when it collides w/ground?
on May 10, 2013 at 12:00:01 pm
I use the Hair module's Spline Dynamics when I need anything rope-like. check out part 3 of this tutorial. Let me know if I can be anymore help.
http://mographcandy.com/blog/2013/4/4/model-ghostbusters-ghost-trap-cinema-...
http://www.mographcandy.com
Twitter: @mographcandy
on May 10, 2013 at 12:25:46 pm
Watched the TUT - Very clear and precise (recommended!).
This saved my day. - Fantastic!
The clue - as you say - is the "Hair module's Spline Dynamics"
Thank you very much!
PerS
