How to achieve animation and post like this work?
COW Forums : Maxon Cinema 4D
Umer Zafar
on Feb 7, 2013 at 7:35:43 pm
Hello everybody,
I am working on a project which involves animation and post production similar to the work in this example:
and
It seems to me there are multiple objects being animated on a single spline but how is the setup made?? thats what i need to know.
Also, any tips on the texture setup and after effects post will be appreciated greatly.
Regards
Muhammed Umer Zafar
Graphic Designer / Animator
City42,
Lahore, Pakistan.
Brian Jones
Re: How to achieve animation and post like this work?
on Feb 8, 2013 at 3:50:27 am
it looks like a SweepNurb and the texture looks quite simple but the overlays in post make it seem more complex
Umer Zafar
on Feb 8, 2013 at 7:07:13 pm
Hey Brian, Can you explain how to achieve this with multiple objects, on a single path??? Details on achieving the texture right are most welcome too..
Regards
Muhammed Umer Zafar
City42,
Lahore, Pakistan.
Brian Jones
on Feb 9, 2013 at 2:09:14 am
you just need to connect the splines you are using for your shapes to run along the path spline. That can be done by making the splines editable and joining them into one object with the Connect command or by putting all the shape splines into a Connect Object and using that in the Sweep.
