Remove an object during an animation
COW Forums : Maxon Cinema 4D
Matthew Paquette
on Sep 1, 2012 at 1:03:57 am
Hi, Im a little new to Cinema 4D. Is there a way i can remove an object in mid animation? For example, I have a cube from frame 1 to frame 100 and on frame 101 the cube is no longer in the scene.
- Matthew Paquette
Brian Jones
Re: Remove an object during an animation
on Sep 1, 2012 at 5:11:10 am
if it's a parametric object you can uncheck Enabled in the Basic properties of the object
if it's parametric or an editable polygon object you can keyframe the Visible in Editor and Visible in Renderer properties
also if it's parametric or an editable polygon object you can add a Display tag and keyframe the Visibility attribute there.
Sean Simon
on Dec 3, 2012 at 4:20:06 am
Click on that object, go into the basic tab. Go to Frame 100 and Ctrl+Click on Visibility in Render+Editor. Go to frame 101 and Change the Visibility to none and Ctrl+Click.
