I was developing complicated project of aircraft engine in AutoCAD all the past week
COW Forums : Autodesk 3ds Max
Charlotte Rogers
on Jul 4, 2018 at 8:04:03 am
But it happened unpleasant thing, my .dwg stopped opening. Only third time I could get access to my project. I saw that some days of my hard work disappeared. I attempted to repair dwg file via some manual guides. Also I used diverse instruments. It could only get back only a day of my work. Now I'm searching for how to get the rest.
Kieran Kennedy
Re: I was developing complicated project of aircraft engine in AutoCAD all the past week
on Jul 6, 2018 at 12:59:04 pm
If a file cannot be opened, take the following steps:
https://knowledge.autodesk.com/support/autocad/troubleshooting/caas/sfdcart...
https://download.cnet.com/Recuva/3000-2242_4-10753287.html
https://www.repairtoolbox.com/autocadrepair.html
• RECOVER command
--Recovers a selected drawing file
--If successful, open and run AUDIT command
--Evaluates drawing integrity and possibly more error correction
--Set system variable AUDITCTL=1 to create a report of audit results
• RECOVERALL command (introduced in AutoCAD 2008)
--Attached and nested xrefs are also opened, repaired, resaved, and closed
• INSERT and EXPLODE
• Start a new DWG with no template
--Run INSERT and selected the corrupted drawing
--Check the “Explode” option
