3ds Max Camera to AE
COW Forums : Autodesk 3ds Max
Chris Haag
on Aug 21, 2013 at 8:33:15 pm
Hello,
I am currently importing a camera and planes from 3ds Max to AE using the compositor link, everything works fine except for one thing, in my max file I am animating the lens of the camera from a super wide 11mm lens to a 18mm. This is the only area I can see the planes not quite track correctly on the render.
Is there a way to get the animated lens information to match in AE?
Todd Stopa
Re: 3ds Max Camera to AE
on Aug 23, 2013 at 4:09:57 am
This might help you out, but im not sure if it does the lense as well
but it works for me. :)
http://www.videocopilot.net/blog/2008/02/import-3d-camera-into-after-effect...
Chris Haag
on Aug 27, 2013 at 9:26:09 pm
Thanks for that. I still have the same issue. I think it's just the way it is. Just can't animate the lens mm in AE.
Chris
http://www.relatedgrey.com
