Convert 3ds models to Cinema 4d anyone?
COW Forums : Autodesk 3ds Max
stephen turcotte
on May 7, 2013 at 3:33:08 pm
I have a series of models that I need formatted for Cinema 4d. I've been able to open up the .3ds files as well as some .OBJ and .FBX files that the client has provided, but the geometry is importing triangulated and and apparently with some nurbs applied. I'd just like a low poly export with a clean mesh. Is anyone able to do this?
David Chappell
Re: Convert 3ds models to Cinema 4d anyone?
on May 20, 2013 at 10:31:39 am
.3ds will always be triangulated.
When you export the .fbx you can select quads/triangles - if this is set wrong at time of export then you'd need to get the originals re-exported properly.
David Chappell
Creative : 3D : Motion graphics
http://www.IncidentalTrees.co.uk
http://www.WhichDimension.com
stephen turcotte
on May 20, 2013 at 11:21:15 am
Thanks for the insight, I'll keep that in mind.
