3ds max
COW Forums : Autodesk 3ds Max
Emmanuel dela cruz
3ds max
on Jan 5, 2010 at 1:06:44 pm
pls. help
how can i unlock the snap setting, everytime i create an object it start in the center. i cant even move the object...
cheers...
Eric Blevins
Re: 3ds max
on Jan 6, 2010 at 2:44:47 am
It sounds like you have path constraint set as the default. When ther is no path to constrai to, the object will 'snap' to the origin and can not be moved. Open your motion panel and check out the position controllers. It most likely shows as path. Click on the '?' and change to 'position xyz'. Click on the make default button when you chose it. This should solve your issue with any new object created.
Emmanuel dela cruz
Re: 3ds max
on Jan 6, 2010 at 4:05:48 am
Eric,
Thanks... solved...
