Help with UVW map modified
COW Forums : Autodesk 3ds Max
Joel Grange
on Apr 22, 2009 at 10:19:42 pm
Hi everyone,
I’m having trouble with my UVW map modifier. I have been using it a lot over the last few years but right now, I cannot get the gizmo to scale- the scale button doesn’t work (or the shortcut on the keyboard), it just does not even appear and the button it blacked out. When I use the shortcut I usually use it “re-direct” me to the move gizmo. The rotate gizmo also works fine. I tried everything, I restarted my system, did a system restore, tried it in several scenes but it did not do it.
HEEELPPP!
Joel
Joel Grange
Re: Help with UVW map modified
on Apr 22, 2009 at 10:53:00 pm
Never mind... I just resolved the problem. I had "Real-world map size" clicked on, inside the UVW map modified, which disables the size gizmo.
Joel
