Applying multiple materials to one polygon
COW Forums : Autodesk 3ds Max
Alex Allgood
on Dec 26, 2007 at 4:12:42 pm
I just created an Ah-64 Apache and would like to add materials to it. The only problem is that the whole thing is a single polygon (For the most part). Is there any way I can add multiple materials to one polygon?
Thanks for anyone that can help!
Colin Thomson
Re: Applying multiple materials to one polygon
on Jan 3, 2008 at 2:56:50 pm
I think you may want to look at the Multi/Sub-Object map. You should really use the Unwrap UVW modifier. Hope this helps ...
Colin
