Wrought Iron Gate
COW Forums : Autodesk 3ds Max
cutter
Wrought Iron Gate
on Sep 25, 2005 at 5:03:45 pm
I have made a very detailed gate out of a line. Adding thickness is a problem. When I adjust the interpolation to add thickness an edit poly modifier crawls. It there a better modifier to give the spline some life?
Gatherer
Re: Wrought Iron Gate
on Sep 30, 2005 at 8:06:53 am
Try lofting a shape along the lines "paths".
I am guessing you are using renderable line presently.
Gatherer
