POSITON OPEN: One of our Architectural Clients is looking for 3D Animator
COW Forums : Autodesk 3ds Max
James Morris Murphy
on Jul 31, 2005 at 4:26:35 pm
Good Morning all.
One of our Architectural Clients is looking to hire a 3D Animator.
I thought there was a Job's area I couldn't find it, so if someone cares to move this post please do.
With your permission:
Position Open:
Daniel P. Coffey & Associates,Ltd., 2003 AIA Chicago Architecture Firm Of The Year is a mid size firm seeking a highly motivated and talented 3D Animator or/and Architect with superb 3D skills.
Our firm is a leader in the field of integrating 3-dimensional CAD into the architectural design process and presentations. We use it extensively for our many high profile, award winning projects in Chicago and around the nation. This is an opportunity for you to have a major affect on the design of our projects.
Job requires extensive knowledge of AutoCad, 3D Studio Max / VIZ, Photoshop and Adobe After Effects/ Premiere. Web site design experience a plus but not required.
Your primary task will be to generate 3D work and create interactive presentations. The candidate will be expected to produce a wide range of work from schematic massing studies to highly detailed animations with global illumination solutions and extensive exterior landscapes and streetscapes.
The job requires the ability to work with and modify AutoCAD data, particularly in 3D Studio Max using editable mesh and editable poly at the sub object level.
Our firm has up to date software and a substantial render farm. Expertise with managing the network render farms (backburner), radiosity, mental ray and light tracer preferred but not required.
You must be able to work with others and be highly organized to manage data, workflow, deadlines and design iterations. Daily direct involvement with the design principals of the firm will be typical.
Portfolio is required for consideration. Animation reel must be on CD, DVD or VHS. Keep it simple, the WORK is important, not the presentation or packaging.
Salary dependent on level experience, opening immediately available.
Daniel P. Coffey & Assoc. Ltd. is an Equal Opportunity/Affirmative Action Employer.
Attn:Daniel P. Coffey, FAIA
233 S. Wacker Suite 5750, Sears Tower
Chicago Il, 60606
ph-312/382-9898; fax-312/382-0820; e-mail dcoffey@dpcaltd.com
Sell the Talent you have to communicate effectively through graphics.
http://www.3d4all.com
