My 2008 Showreel
COW Forums : Demo Reels
Justin Stein
My 2008 Showreel
on Jun 3, 2008 at 5:23:41 am
Thank you for talking the time to view my reel. Any comments are appreciated.
George Loch
Re: My 2008 Showreel
on Jun 13, 2008 at 10:06:14 pm
I hope you have your thickest skin on...
First of all, I don't recommend doing titles like "Motion graphics". It will or should be obvious what you are showing from the initial slate and the content.
Now, most of what you show needs some solid refinement. There is some shaky video and 'bumpy' animation that should be made flawless. ie. the vegas clip has something popup at the start and it moves like bad After Effects keyframes. A lot of the samples feel like you were playing around with no clear objective. My advice is to go back through it all and ask yourself why you did each piece. If you are not sure, then throw it out and replace it with something more solid. Each item should have a strong idea behind it and not be effects-driven.
In order to stand out in a very crowded field like mograph, you need a sharp, focused reel and your not there yet.
-gl
Prologue Media
http://www.prologuemedia.com
