Layout
COW Forums : Demo Reels
dcribber
Layout
on Apr 4, 2005 at 3:30:32 pm
What do you guys think of putting the standard "wow 'em montage" at the end of the piece instead of starting off with it. What I am thinking is starting off with 4 or 5 :30 second editing pieces then a transition to a name dropping/here's what we do with fancy graphics/wow 'em montage to close.
DaveC
plasma
Re: Layout
on Apr 4, 2005 at 7:36:53 pm
not sure what type of work you do. but i tend to include no montages.
Vinnie
Re: Layout
on Apr 4, 2005 at 9:10:57 pm
I think you need to grab your audience's attention first. I dont think it matters if you grab it with a :30 sec spot or montage. I would play with the idea of starting with a spot then going into a montage from the end of the spot. Then lead into another spot with the end of the montage.....
Like this.....Spot...montage...Spot....different montage....spot...montage...contact info
just thinking outloud....dont listen...
vinnie
dcribber
Re: Layout
on Apr 5, 2005 at 4:29:14 pm
Acutally I think that could be a cool idea. Something I hadn't thought of. I'll give it a try.
DaveC
