Compress Keyframe timing
COW Forums : Apple Motion
KB Burnfield
on Jun 19, 2019 at 1:38:03 pm
I've got an animation I'm working on and it's 10 seconds long but after working on it I realize it would be better at 5, what I've done in the past is export it and in FCPX I just speed it up but I recall there's a way to go into the keyframe editor and "compress" the time or distances between keyframes.... isn't there?
I can't find any reference to this anywhere online so I thought I'd ask.
thx
Simon Ubsdell
Re: Compress Keyframe timing
on Jun 19, 2019 at 6:06:38 pm
Draw around the keyframes using the Transform Keyframes Tool (highlighted in blue) and then you can adjust the resulting bounding box to resize the animation.
Simon Ubsdell
hawaiki
Simon Ubsdell
on Jun 19, 2019 at 7:40:32 pm
Of course, if you don't have 3D groups you could always make a master group for your entire project and put everything inside it.
If you then make a Clone of that group, you can retime it using either the Retime Behaviors or by keyframing the Timing controls for the group.
Simon Ubsdell
hawaiki
KB Burnfield
on Jun 20, 2019 at 1:06:57 am
THANKS!!!
