distorting the location line of a gradient
COW Forums : Apple Motion
Dan Gifford
on Nov 28, 2017 at 5:59:40 pm
Hello.
I have a gradient, applied as an image mask, that I'm using to change the opacity of ONE side of a shape over time.
It works - but as the bezier is a curve, I wanted to distort the 'location' (the name Motion uses to describe of the central point of the gradient) to fit the shape much better.
I wandered if anyone could help me do this, or think of another way to achieve the effect?
Thanks Dan
Mac pro, motion 5, Elcaptian.
Simon Ubsdell
Re: distorting the location line of a gradient
on Nov 29, 2017 at 10:36:47 am
You could try using a Bulge to add some curvature the the gradient. Alternatively you could use a radial gradient but it would be less successful for what I think you want.
Simon Ubsdell
tokyo productions
hawaiki
Simon Ubsdell
on Dec 4, 2017 at 9:08:52 pm
Here's a much better idea:
Create two color solids one for each side of your gradient.
Create a curved mask for the upper layer.
Add a directional blur to the mask along the axis of the gradient and increase as required.
Very controllable.
Simon Ubsdell
tokyo productions
hawaiki
Dan Gifford
on Dec 22, 2017 at 7:49:24 am
Thank you! I just tried it now, at the very end of the project and it worked really well. :o)
Took me a while to work out exactly whet you meant, but I got it.😊
