stopping the Play
COW Forums : Apple Motion
Terry Maloney
stopping the Play
on Sep 8, 2017 at 2:25:21 am
Hi, 😃
Many times I hit the spacebar to stop the playback; but playback keeps on going.
Then when I click in the timeline area and push the spacebar, it will stop.
I either do that or ----
I have to push " Command 7" two times. Once to get turn off the view to timeline and then once to turn on timeline.
Is this normal? Am I doing something wrong?
Thank you.
Terry
Terry Maloney
Re: stopping the Play
on Sep 9, 2017 at 5:06:30 am
Hi 😃
For you viewers, I found out there are no preset shortcuts.
But my work around is with yKey (formally iKey). Just create a short cut that hits command 7, pause, command 7, pause, & then spacebar. Put it all under one key command --- possibly "command spacebar".
Cheers,
Terry 😊
