Change the name in the Behaviors.
COW Forums : Apple Motion
Terry Maloney
on Aug 23, 2017 at 1:08:06 pm
Hi, 😊
I am making many audio behaviors on one JPG over time. Their names are defaulted as Audio, Audio 1; Audio 2 etc.
I need to make these names more descriptive. I can't use the source material because they have their own descriptive names.
Thank you,
Terry
Mark Spencer
Re: Change the name in the Behaviors.
on Aug 23, 2017 at 1:25:34 pm
You can rename any behavior (or any filter or mask or layer or group) to anything you want. Just double-click the name in the Layers list.
Mark Spencer
Freelance Producer/Editor/Motion Graphics Artist
Apple-certified Master Trainer
Author, Motion 4 from Peachpit Press
http://www.applemotion.net
Terry Maloney
on Aug 23, 2017 at 1:49:04 pm
Hi Mark, 😊
There are no behaviors in the layers list. I go to properties of the picture and add a audio parameter there. Then the Behaviors window automatically opens up and I make my adjustments there.
If I add a move behavior to the project the other way, I don't know how to make it controlled by audio. It's all key frames then.
Terry
Mark Spencer
on Aug 23, 2017 at 2:07:12 pm
If the behavior isn't appearing below the layer you have it applied to in the layers list, then you have disabled the view of behaviors - small icon at the bottom of the layers list.
Mark Spencer
Simon Ubsdell
on Aug 23, 2017 at 2:10:23 pm
[Terry Maloney] "There are no behaviors in the layers list."
That's because you have disabled the Show Behaviors button at the bottom of the Layers panel:
Turn it back on to see your behaviors in the Layers Panel where you will be able to rename them.
Simon Ubsdell
tokyo productions
hawaiki
