Set XY of filter by tracking data
COW Forums : Apple Motion
Peter Silie
on Aug 19, 2017 at 2:15:06 pm
I found a filter for "bulging" (sorry, I have only the german version and don't know the original english title). The setting of center XY location should be set by tracking data. I created a tracking analysis on the video to get the path of moving of the object, but I don't know how to connect/bind it to the center location of the filter.
Is this possible at all?
Thanks in advance
Dirk
Mark Spencer
Re: Set XY of filter by tracking data
on Aug 19, 2017 at 3:17:20 pm
Yes - add the track parameter behavior to that parameter then set the analysis data as the track source.
Mark Spencer
Freelance Producer/Editor/Motion Graphics Artist
Apple-certified Master Trainer
Author, Motion 4 from Peachpit Press
http://www.applemotion.net
Peter Silie
on Aug 19, 2017 at 3:38:58 pm
I think I didn't get it. On the filter itself I could not add the Motion tracking "change" behaviour. When droping it onto that filter it is inserted below in the same group but not under the filter. There are several other filters assigned to that clip. But only that single filter should change its center possition accordingly to the Motion Analysis data.
Where do I have to move and drop which item?
Mark Spencer
on Aug 19, 2017 at 9:06:20 pm
Mark Spencer
Peter Silie
on Aug 20, 2017 at 9:10:54 am
Aaaahhhh! Thank you!
