changing anchor points
COW Forums : Apple Motion
Terry Maloney
on Aug 1, 2017 at 3:56:07 am
Hi
I want to rotate a jpg. I want to rotate with the anchor point at the bottom and then rotate the jpg with the anchor at the top. So I set up these keyframes which change the anchor point of the jpg.
However, the position of the jpg moved up and down. I want the jpg to stay still; but I want the anchor point to change position.
Can you tell me how to do this? Thank you.
Cheers,
Terry 😃
Mark Spencer
Re: changing anchor points
on Aug 1, 2017 at 4:16:38 am
Use the Anchor Point tool, rather than the Inspector - it changes both Position and Anchor so that the layer stays still relative to the Canvas.
Mark Spencer
Freelance Producer/Editor/Motion Graphics Artist
Apple-certified Master Trainer
Author, Motion 4 from Peachpit Press
http://www.applemotion.net
Terry Maloney
on Aug 2, 2017 at 7:55:28 pm
Thank you..
