Possible to set the starting rotation when following a motion path?
COW Forums : Apple Motion
Brian Dunning
on Mar 6, 2017 at 3:32:45 pm
I have my object correctly following a motion path, and "Snap Alignment to Motion" is set and working -- except my object is pointing the wrong way. Think of a race car driving sideways around a track, always 90 degrees off its direction of motion. I can't seem to find a way to calibrate the rotation angle dictated by Snap Alignment to Motion. Is there a way to do this?
Simon Ubsdell
Re: Possible to set the starting rotation when following a motion path?
on Mar 6, 2017 at 4:29:26 pm
Simply swap the Axis of the Snap Alignment Behavior from Horizontal to Vertical.
Simon Ubsdell
tokyo productions
hawaiki
Brian Dunning
on Mar 6, 2017 at 4:31:48 pm
My bad, I shouldn't have said 90 degrees, because it's some random angle. Neither horizontal nor vertical gives me the correct angle. I need finer control than that, I'd say it's off by about 60 degrees. Thanks for your speedy reply though. :-)
Brian Dunning
on Mar 6, 2017 at 4:36:29 pm
I am currently hacking this by rotating the sprites in Photoshop and re-importing them. Does the job in a one-off way, but it's a hack. Since there are multiple motion paths and I want it pointing different ways as it travels, I have to make a different file for each. Not the end of the world.
Simon Ubsdell
on Mar 6, 2017 at 4:36:56 pm
That sounds curious.
But the easy solution is to put your "racing car" into a group and apply the Motion Path and Snap Alignment to the group.
Then you can adjust the rotation of the "racing car" layer to taste.
Simon Ubsdell
tokyo productions
hawaiki
Brian Dunning
on Mar 6, 2017 at 4:39:03 pm
Oooohhhhh --- now I feel like an idiot for not thinking of that. Thanks, does the trick. :-)
