How to modified second keyframe using slider
COW Forums : Apple Motion
Doni Donovan
on Jan 20, 2017 at 12:58:53 pm
Can some tell me is possible to change the last value that already have 2 keyframes using a slider?
i really hope someone can help me
Robin S. Kurz
Re: How to modified second keyframe using slider
on Jan 21, 2017 at 11:33:56 am
Odd question. Without knowing which parameter we're talking about and/or far more precisely what it is you're trying to do, this could only turn into an endless guessing game.
If it doesn't have a slider, there's no sliding. But pretty much every parameter value can be scrubbed.
- RK
____________________________________________________
Deutsch? Hier gibt es ein umfassendes FCP X Training für dich!
Doni Donovan
on Jan 21, 2017 at 5:57:42 pm
Hi Robin..
For example i have 2 keyframes which is moving the x position of rectangle from 0 to 100..
Ao i want to change the second keyframe (100) by slider without changing the first keyframes (0)
Doni Donovan
on Jan 21, 2017 at 6:23:57 pm
I have to publish the slider so i can change it on FCP
Robin S. Kurz
on Jan 21, 2017 at 6:50:47 pm
That's what I suspected.
You can publish the position parameters as a whole, but you cannot publish any one value of any one keyframe, no.
- RK
Doni Donovan
on Jan 22, 2017 at 1:09:00 am
Thanks for your answer Robin.
I know we cant publish only one of two animated keyframes but i am sure apple motion can do that in another way..
Maybe using rig or behavior but i dont know i am still new with motion
Robin S. Kurz
on Jan 22, 2017 at 4:34:53 pm
Again, without knowing exactly what you're trying to do, there is little in terms of specifics I can give you.
Maybe take a look here: http://www.rippletraining.com/products/motion/rigging-publishing-for-motion...
- RK
