Do you recommend Photoshop or Illustrator for Motion?
COW Forums : Apple Motion
Glenn Payne
on Jan 18, 2017 at 10:53:19 pm
Hey guys,
I'm new to Motion 5 and am about to start an animated intro for my film. It'll be a simple but speedy 2D "cut out' looking sequence along the lines of the intro for the AMC show "Turn". Do you guys recommend using Photoshop or Illustrator when creating the initial images I'll send into Motion 5? I won't be dealing with any text until it gets to Motion.
Thanks for any info!
Glenn
Turn Sample:
Robin S. Kurz
Re: Do you recommend Photoshop or Illustrator for Motion?
on Jan 19, 2017 at 12:17:29 pm
Depends on what exactly you're looking to create. Illustrator files can't be imported (other than as PDF) into Motion. Of course most things (such as shapes, masks etc.) are just as well if not better made directly in Motion, with the accompanying flexibility. Question is to what degree either apps are in fact even necessary. But if has to be the one or other, then you're best using high-res PS files.
- RK
____________________________________________________
Deutsch? Hier gibt es ein umfassendes FCP X Training für dich!
