Title "Fade In/Out" Timing
COW Forums : Apple Motion
Chad Greene
on Nov 28, 2016 at 10:47:41 pm
I created a new FCP Title in Motion and added a fade in/out behavior set to 24 frames for both in/out. When I use the title in FCPX it fades correctly when first dropped in, but when I lengthen or shorten the clip, the fade lengthens and shortens as well. Is there a way to make the fade behavior keep it's timing regardless of the title's length?
Chad Greene : Mahoney Media : Minneapolis, Minnesota : 2x2.66 GHz 6-Core Intel Xeon, 12GB Ram, OS 10.11 FCPX, Kona-LHi
Robin S. Kurz
Re: Title "Fade In/Out" Timing
on Nov 29, 2016 at 10:31:15 am
You need to use a timeline markers after and before each fade and set them to "Build In" and "Build Out" respectively. Whether "- optional" or "- mandatory" is up to you.
- RK
____________________________________________________
Deutsch? Hier gibt es ein umfassendes FCP X Training für dich!
Chad Greene
on Nov 29, 2016 at 5:23:45 pm
Thank you. That was just the clue I needed. I found the details in the Motion help files.
https://help.apple.com/motion/mac/5.3/index.html?localePath=en.lproj#/motn1...
My title is working perfectly now.
