Text exported from Motion comes out garbled
COW Forums : Apple Motion
Jason Brown
on Oct 16, 2016 at 10:39:31 pm
I have some animated text that in Motion 5 that when I export the text looks garbled. Some info that I hope helps:
1. The "Path Shape" is set to "geometry" and follows the circle in the image.
2. There are 4 image mask on the circle.
3. There is a Disk Warp filter that animates through the image as the video goes.
4. I render it with Color set to color + Alpha with Premultiply checked.
4a. I've tried different codecs.
4b. I've also tried publishing it to FCPX.
Here is an image of what I get. The 1st is what I see in Motion, the 2nd is what I get after export. Thank you, any help would be greatly appreciated.
Robin S. Kurz
Re: Text exported from Motion comes out garbled
on Oct 17, 2016 at 8:07:31 am
You might consider posting that here: https://www.facebook.com/groups/apple.motion/ , possibly even along with the actual file. At least I for one couldn't give you a useful explanation without actually seeing the project. I could only suspect that it may have something to do with the font.
- RK
____________________________________________________
Deutsch? Hier gibt es ein umfassendes FCP X Training für dich!
Jason Brown
on Oct 17, 2016 at 2:29:00 pm
Thank you for the info RK. I will definitely check the site out, hopefully they have some info.
