can you animate a path line
COW Forums : Apple Motion
Terry Maloney
on Aug 6, 2016 at 8:11:31 am
Hello,
Can you animate a path line? As the words pass by the line might go lower or slant etc? And then change the slant?
Thank you,
Terry
Simon Ubsdell
Re: can you animate a path line
on Aug 6, 2016 at 9:42:26 am
Yes, you can certainly animate a text path, if that's what you mean. Turn on Record Animation, select the Edit Points tool and keyframe your path - or you can simply rotate it or scale it or whatever you want to do. The text will now follow your animated path. You can also do this with th built-in paths, but you probably want the more flexible option of using Geometry.
Simon Ubsdell
tokyo productions
hawaiki
