using your own image in a particle emitter
COW Forums : Apple Motion
Terry Maloney
on Aug 6, 2016 at 2:05:36 am
Hello
Is it possible to import your own image into Motion 5 to be used in a particle emitter?
Thank you.
Terry
Mark Spencer
Re: using your own image in a particle emitter
on Aug 6, 2016 at 2:19:57 am
Yes - you can use your own image, or video, or text, or group of objects - just about anything.
Mark Spencer
Freelance Producer/Editor/Motion Graphics Artist
Apple-certified Master Trainer
Author, Motion 4 from Peachpit Press
http://www.applemotion.net
Terry Maloney
on Aug 6, 2016 at 3:02:15 am
Thanks, Mark, :D
Could you please direct me to the place where you do that ?
Terry
Mark Spencer
on Aug 8, 2016 at 8:54:16 pm
Terry, you just select the object you want and then make an emitter.
Mark Spencer
Terry Maloney
on Aug 9, 2016 at 3:06:50 am
Hi Mark,
I thought you had to put the image in the contents folder/ particle images.
But if you don't, this is much easier. Thanks a lot for your help. :D
Terry
