Tracking a lightsaber using Analyze Motion and Replicator
COW Forums : Apple Motion
<< PREVIOUS   •   VIEW ALL   •   PRINT
Tom Söderlund
on Jul 16, 2016 at 6:11:15 pm
I'm trying to create a lightsaber effect in Apple Motion.
As source material, I have a video a lightsaber with two tracking points taped on. I used Analyze Motion with some manual fixing (BTW1: can I manually add tracking points?):
My first approach was using the Line tool in Motion, but gave that up since a line is made out of a center point, not two points. From this thread I got inspired to try a point/circle and Replicator instead.
My current approach is this:
* Replicator itself has position 0/0.
* Replicator Start Point is Link:ed to Track 1 in Analyze Motion (BTW2: why do I have two "Result" under Track 1 and Track 2?).
* Replicator End Point is Link:ed to Track 2 in Analyze Motion.
Then I get this:
It's almost there, but as you can see I have an offset, and it's not a straight X/Y offset that I easily can fix, looks more circular. Any ideas?
Tom Söderlund
Re: Tracking a lightsaber using Analyze Motion and Replicator
on Jul 16, 2016 at 6:48:15 pm
Update: I did a second attempt with the Line tool:
  • Changed the Anchor Point to start of the line.
  • Changed position to match the base of the lightsaber in the video.
  • Used Match Move with my previous tracking points.
  • Current results:
    Much better starting point, but I'm happy for any feedback you might have on my approach!
    Leon Zandman
    on Sep 15, 2016 at 7:46:25 pm
    Did you already check YouTube. There are plenty of videos explaining how to do a cool light saber effect.
