simultaneous behaviors
COW Forums : Apple Motion
Terry Maloney
on Jul 3, 2016 at 5:59:51 am
Hi
Can I apply two behaviors to one object at the same time in Motion 5?
I put two in but only only one would work at a time.
Terry
Robin S. Kurz
Re: simultaneous behaviors
on Jul 3, 2016 at 8:07:48 am
Depends entirely on the behaviors, which parameters they control, HOW they are applied etc. Obviously some will cancel each other out.
- RK
____________________________________________________
Deutsch? Hier gibt es ein umfassendes FCP X Training für dich!
Terry Maloney
on Jul 3, 2016 at 8:54:19 am
I had one object which was moving in one direction.
I put right underneath it a behavior which would make the object get bigger.
When the object moved to the end, that's when it started getting bigger even though the getting bigger behavior was on top of it in the time line. I would think that these would not cancel each other out.
What I am wondering is whether I have to put the behavior in a separate group. Or in a special place.
When I put the 2nd behavior after the first behavior is done, then it works.
Thank you,
Terry
Robin S. Kurz
on Jul 3, 2016 at 10:21:43 am
I would simply use PARAMETER behaviors on position and scale in that case. Or yes, you could put one on the layer and the other on the group.
- RK
