Pass Through, Normal et al within a composition
COW Forums : Apple Motion
Lawrence Eaton
on Apr 2, 2016 at 7:18:54 pm
I took it upon myself to break up a project to manageable "lumps", with the thought that I could simply drag and drop them to build the final version.
It's all worked rather well, except one part.
When I drag and drop each component project into a "Master" project I seem to have "Pass Through" as the default blend mode. I've tried changing this to normal at the "Group" level or at the individual level but I still seem to have a semi transparent graphic element, no matter which one I use.
Is this WAD, or maybe I've missed something? Can anyone help, please ?
Lawrence
Bret Williams
Re: Pass Through, Normal et al within a composition
on Apr 8, 2016 at 1:56:39 pm
Blend mode and transparency are two different things. So if you have transparent items in your group, they need to be adjusted within the group itself.
