Keeping image in iPhone frame
COW Forums : Apple Motion
Greg Ball
on Mar 30, 2016 at 12:57:48 pm
I had someone create an iPhone frame with Alpha channel for me, so I can change the screens and also have a finger tap buttons. That all works fine. However the first animation has the phone flip over and into frame. I can't seem to figure out how to insert the first image into the phone and have the image in the phone follow along with the motion of the phone so it always stays in place.
Can someone give me the steps to follow?
Greg Ball, President
Ball Media Innovations, Inc.
https://www.ballmediainnovations.com
Robin S. Kurz
Re: Keeping image in iPhone frame
on Mar 31, 2016 at 9:30:02 am
http://www.coremelt.com/products/trackx-powered-by-mocha.html
- RK
____________________________________________________
Deutsch? Hier gibt es ein umfassendes FCP X Training für dich!
John Rofrano
on Apr 1, 2016 at 11:09:26 am
[Robin S. Kurz] "http://www.coremelt.com/products/trackx-powered-by-mocha.html"
+1
You need a planner tracker for this kind of work. CoreMelt Track-X with the Perspective Tracking option should do the trick.
~jr
http://www.johnrofrano.com
http://www.vasstsoftware.com
Greg Ball
on Apr 4, 2016 at 9:06:06 pm
Does this work in FCP 7?
John Rofrano
on Apr 4, 2016 at 11:20:44 pm
[Greg Ball] "Does this work in FCP 7?"
Unfortunately, No. CoreMelt SliceX, TrackX, and DriveX are only available for FCP X. (hence the 'X' in their names) ;-)
~jr
Robin S. Kurz
on Apr 5, 2016 at 1:33:08 pm
[John Rofrano] "Unfortunately, No. CoreMelt SliceX, TrackX, and DriveX are only available for FCP X. "
Actually... yes AND no. They ARE available in Motion, only just the masking functionality, not the tracking.
But then, is that really relevant? I'd say using it in FCP is much easier anyway and you don't lose any functionality or options.
- RK
John Rofrano
on Apr 5, 2016 at 8:22:05 pm
[Robin S. Kurz] "I'd say using it in FCP is much easier anyway and you don't lose any functionality or options."
Agreed. Very easy to use in FCP X.
~jr
Greg Ball
on Apr 6, 2016 at 8:30:54 pm
So is there anyway to do this in motion? I'm not editing on FCPX yet.
Robin S. Kurz
on Apr 7, 2016 at 8:35:20 am
[Greg Ball] "So is there anyway to do this in motion?"
Sure. With simple key framing of the "Four Corner" properties or possibly even with a corner pin track. Motion has a POINT tracker built in. There are endless YouTube videos on the subject.
- RK
John Rofrano
on Apr 7, 2016 at 12:15:56 pm
Yea, if you have 4 clean corners to track and they never leave the frame or become obscured by other objects, the point tracker will work fine. The CoreMelt plug-ins contain the Mocha tracker which is a Planar Tracker which is more capable than a simple point tracker but a point tracker will work if you have clean points to track and it's built into Motion.
Try this tutorial. I believe it will show you exactly what you need to know:
Match-moving a Picture into a Frame With Apple Motion 5
~jr
