Non transparent image showing text through it
COW Forums : Apple Motion
Lawrence Eaton
on Mar 24, 2016 at 6:42:19 pm
I'm trying to put together a simple animation with an image and some text rotating around it. My problem is that the text is showing through the PSD image of the blue clouds. Opacity is 100% on the image .
Anyone, please?
9909_screenshot20160324at14.36.39.png.zip
Lawrence
Robin S. Kurz
Re: Non transparent image showing text through it
on Mar 25, 2016 at 2:52:13 pm
That's because the image is a 2D object and the text 3D. 3D text exists in it's own space. For them to obstruct each other, they BOTH have to be EITHER OR, not mixed. And the only thing that can currently be 3D is TEXT (i.e. anything that's a FONT).
- RK
____________________________________________________
Deutsch? Hier gibt es ein umfassendes FCP X Training für dich!
Lawrence Eaton
on Mar 25, 2016 at 6:13:34 pm
Thanks Robin worked a treat.
Lawrence
Robin S. Kurz
on Mar 25, 2016 at 6:19:15 pm
Meaning you did what? Just out of curiosity...
- RK
Lawrence Eaton
on Mar 25, 2016 at 6:28:21 pm
Robin,
I took the text back to 2D and everything snapped into place as expected. Would be nice if 3D text would also do this, though. Maybe in the next release??
Lawrence
Robin S. Kurz
on Mar 27, 2016 at 3:59:12 pm
The alternative of course being, that you do it the other way around. ;) Change the graphic into a 3D object. Make an SVG version of it, go to glyphter.com (which actually already has a cloud like that in its standard glyphs) and make a font out of it...
- RK
Lawrence Eaton
on Mar 27, 2016 at 4:54:13 pm
Robin,
This is one option I created with your help.
9922_icloudvsphotostreamtestappledeviceshdbestquality.m4v.zip
Lawrence
