Motion Blur not working in FCP X Templates
COW Forums : Apple Motion
Brett Sherman
on Mar 10, 2016 at 1:03:19 pm
This is driving me crazy. From what I can tell, motion blur doesn't really work in Motion Templates.
I made a Pan and Zoom template for animating motion on photos. I want to have your typical 180 degree motion blur on it to smooth out the motion. However, no matter what I do it just doesn't work right. I upped the shutter angle to 1800 degrees (10X normal) and it provides only a slight bit of motion blur on only really fast moving things (I'd guess it's actually more like a 45 degree shutter angle). There is no way to go above 1800 degrees so I'm stuck. Any ideas?
Here is the template:
https://www.dropbox.com/s/f19gjyal3ej29k1/Bretts%20Pan%20and%20Zoom.zip?dl=...
Mark Spencer
Re: Motion Blur not working in FCP X Templates
on Mar 10, 2016 at 2:20:38 pm
Brett, here's what you need to do:
Mark Spencer
Freelance Producer/Editor/Motion Graphics Artist
Apple-certified Master Trainer
Author, Motion 4 from Peachpit Press
http://www.applemotion.net
Brett Sherman
on Mar 11, 2016 at 4:46:18 pm
Awesome. Thanks!
It didn't really work inside the template as it messed up my "Smooth Move" rig setup. It just got stuck at the begin setting and didn't move. I think it probably has something to do with the "Loop" marker.
But I did have success using it as an Adjustment layer in FCP X. That will do for now.
Why Motion scales the time of the motion blur doesn't make a bit of sense though.
