Title Template Causing Frame Blending in FCP
COW Forums : Apple Motion
Daniel McCullum
on Feb 12, 2016 at 4:27:47 pm
Hi all,
Have been diving into Motion and FCPX the last few days, evaluating for a possible transition from Premiere. Really love the amazing integration between the two apps.
I have a title template built in motion that blurs out a portion of the background image in FCP using a clone of the Title Background layer (as outlined here https://discussions.apple.com/thread/6734275?start=0&tstart=0)
Here's where the problem begins. I have a quick build in and a quick build out, and then the middle is effectively a freeze frame. However, when I stretch the title layer in FCP beyond the original template length, I start getting this frame blending/echo effect on the footage below.
I'm guessing this is because the Motion template applies a speed modification not only to the animated text layer but also to the Title Background layer. Hypothetically I could I'm wondering if anyone has found a solution to this problem other than making the title template really long and shortening where needed.
Robin S. Kurz
Re: Title Template Causing Frame Blending in FCP
on Feb 13, 2016 at 12:16:26 pm
Any chance you could post the file so one could have a look? Otherwise one can only guess. But it's certainly nothing I've seen happen before.
- RK
____________________________________________________
Deutsch? Hier gibt es ein umfassendes FCP X Training für dich!
Daniel McCullum
on Feb 16, 2016 at 3:44:25 pm
Here is a copy of the Motion project:
https://dl.dropboxusercontent.com/u/8087888/Tease%20-%20Improved.zip
To replicate the problem, simply insert as a Final Cut title and extend the length past the default (the longer you stretch, the more pronounced the effect)
