Making FCPX Templates
COW Forums : Apple Motion
Chad Greene
on Jan 25, 2016 at 8:56:52 pm
I am cutting a project that could really use some motion templates to make life easier. I keep having to build and keyframe the same thing in FCPX that I believe could be done MUCH easier if I knew how to build a motion template. Where is a good place to learn the basics of motion and creating templates.
Here is a sample of something I am tired of building manually.
Chad Greene : Mahoney Media : Minneapolis, Minnesota : 2x2.66 GHz 6-Core Intel Xeon, 12GB Ram, OS 10.9 FCPX, Kona-LHi
Mark Spencer
Re: Making FCPX Templates
on Jan 25, 2016 at 9:18:48 pm
Well I'm biased but I'd say this is a pretty good place to start: http://www.rippletraining.com/products/motion/rigging-publishing-for-motion...
Mark Spencer
Freelance Producer/Editor/Motion Graphics Artist
Apple-certified Master Trainer
Author, Motion 4 from Peachpit Press
http://www.applemotion.net
Robin S. Kurz
on Jan 26, 2016 at 9:05:15 am
I agree with Mark. And I'd say I'm pretty UNbiased. ;)
But then, if you've made that effect ONCE in FCP, there's always the "Save Effect Preset" option, too. No need to do the same thing over and over.
- RK
____________________________________________________
Deutsch? Hier gibt es ein umfassendes FCP X Training für dich!
Chad Greene
on Jan 26, 2016 at 5:08:52 pm
Mark, I find your guys stuff helpful so I will have to check out this training.
Robin, I have been copying my settings from one photo to another but yes I should try saving a preset.
Ultimately I would love to have the camera sound AND the transition flash also be apart of the overall look. Just drop a photo on the drop zone and have one slider to adjust the overall speed then have rotation and scale direction selectors to adjust the overall look. Then I would stack multiple generators to get the photos stacking at the right time for the vo.
Does this sound like a complex template to build? Is this something I can learn in a day or should I be looking for an expert to build it for me?
Mark Spencer
on Jan 26, 2016 at 6:04:43 pm
You can't have audio in a Motion template that is published to FCP X.
Mark Spencer
Robin S. Kurz
on Jan 26, 2016 at 6:23:49 pm
[Mark Spencer] "You can't have audio in a Motion template that is published to FCP X."
Yeah. Audio can't be incorporated into templates. Unfortunately.
[Chad Greene] "Ultimately I would love to have the camera sound AND the transition flash also be apart of the overall look. "
Again, simply make an effect preset. If you want to incorporate anything else (FX, sound etc.) simply make a compound clip, duplicate it and change the contents as needed. Done.
[Chad Greene] "Does this sound like a complex template to build? Is this something I can learn in a day or should I be looking for an expert to build it for me?"
On the one hand I'd say that if you can build it (in this case meaning that/your particular effect) in FCP, then you're about 5% away from building it in Motion. On the other hand, it's not complex enough to justify going to Motion for it imho. Save learning Motion for something else. Seeing that you'd still have to do (audio etc.) work in FCP once it's there, it seems overkill. I'd go the compound clip and effect preset route. I do it all the time and know my around Motion very well.
- RK
Chad Greene
on Jan 26, 2016 at 7:56:26 pm
Thank you Robin. I will give the compound idea a more serious look.
