shine behaviour - nasty outline on text
COW Forums : Apple Motion
phil sheldon
on Jan 5, 2016 at 10:26:05 am
Hi all
got an issue with the shine behaviour putting a nasty outline on some text. any ideas how to remove it? i've tried removing outlines in the bahaviour but it just wont go. images below hopefully!
the top one shows the text before the behaviour starts, the other during
any help most appreciated
Phil
Robin S. Kurz
Re: shine behaviour - nasty outline on text
on Jan 6, 2016 at 10:56:10 am
[phil sheldon] "putting a nasty outline on some text"
That actually appears to be a weird bug in the behavior. What you're seeing is the initial "Blur" state that is subsequently animated. For some reason, even when set to ZERO, it is still applying an ever so small amount of blur that peeks out from behind, which it of course shouldn't. Unfortunately there's no easy solution that I can find.
- RK
____________________________________________________
Deutsch? Hier gibt es ein umfassendes FCP X Training für dich!
phil sheldon
on Jan 6, 2016 at 4:01:10 pm
wow - i think this is the first time it isn't me doing something stupid!!
thanks loads for having a look for me, changing the font colour has mostly hidden it. not ideal but will have to do
thanks for your help
Phil
Bret Williams
on Jan 7, 2016 at 10:08:35 pm
Animate the transparency/mix of the effect?
