Need to add a scene on side of vehicle door
COW Forums : Apple Motion
geri bastian
on Nov 24, 2015 at 8:24:42 pm
Hi, Need some advice on how to create an effect. I'm using Motion 5.2.1 and I have a shot of an expedition and I want to add a scene on the door. What is the best way to create this so it follows all the curves of the vehicle? Any advice is greatly appreciated
Geri
Deyson Ortiz
Re: Need to add a scene on side of vehicle door
on Nov 24, 2015 at 10:27:09 pm
Do you have a sample of the clip that you can share? This will help us serve you better. :)
- Deyson Ortiz - Editor / Motion Graphics
_______________________________________
- View my work at: http://www.Deyson.com
- Download Free Motion Master Templates at: http://www.motion-master-templates.com/
- Watch my Apple Motion Podcasts at: http://my.creativecow.net/Deyson-Ortiz/podcasts
geri bastian
on Nov 24, 2015 at 11:59:49 pm
Here is the wide shot and close up. I plan on putting the testimonial in the door and then cut to a close up with the same testimonial in the shot.
geri bastian
on Nov 25, 2015 at 12:02:39 am
Deyson Ortiz
on Nov 25, 2015 at 12:04:11 am
Is the shot moving? What is the scene you want to add to the door?
geri bastian
on Nov 25, 2015 at 2:05:09 am
yes the shot is a slow dolly and the scene I want to add is a keyed waste up shot of man giving a testimonial
Robin S. Kurz
on Nov 25, 2015 at 9:51:51 am
You could simply use Motion's corner-pin tracker, but I would personally opt for Coremelt's TrackX and do it in FCP X where I'm assuming you're doing the rest anyway, no? TrackX is not only much easier to handle, but the results will be much better more often than not.
- RK
____________________________________________________
Deutsch? Hier gibt es ein umfassendes FCP X Training für dich!
geri bastian
on Nov 25, 2015 at 2:52:49 pm
Thanks RK, but I'm looking for the video to also follow the indents in the middle of the door as well
Robin S. Kurz
on Nov 25, 2015 at 2:56:32 pm
[geri bastian] "to also follow the indents in the middle of the door as well"
Well, you're not going to find anything IN or FOR Motion for that. Unless a displacement map is enough, which generally isn't quite as elegant as say, a mesh-warp of sorts, which is what I'm assuming you're thinking of.
- RK
geri bastian
on Nov 25, 2015 at 3:01:54 pm
yes I was looking for a simple mapping concept. I have not tried the displacement map.
Robin S. Kurz
on Nov 25, 2015 at 3:03:35 pm
[geri bastian] "I have not tried the displacement map."
Well, you'd have to MAKE it first. ;)
- RK
Deyson Ortiz
on Nov 25, 2015 at 3:28:32 pm
Do you have a shot of the testimonial you plan to place on the car?
