New Lens Flare Tutorial
COW Forums : Apple Motion
Andy Dolphin
on Nov 6, 2015 at 12:00:02 pm
My first Motion 5 tutorial demonstrates a simple method for building a basic lens flare effect entirely in Motion 5.
It's not intended for photo-realistic effects but with a little work, it can produce attractive results.
Part 2 will hopefully not be too far away.
Andy Dolphin
Re: New Lens Flare Tutorial
on Nov 7, 2015 at 3:28:17 pm
Part 2
Adding the Lens Flare Generator and a replicator. The whole flare assembly is animated using a single controller.
Some steps could be simplified by duplicating layers or copying links then simply changing parameters.
I used the flare built in the tutorial to create the final transition by exporting a short Pro-Res file then importing into the composite project (also done in Motion 5) and adding a blend mode.
There's plenty more that can be done to this to make it more interactive and adaptable.
