Importing new content to keep in Motion
COW Forums : Apple Motion
Mark Suszko
on Oct 30, 2015 at 4:50:12 pm
So I have some content (image files and .mov files with alphas) on DVD and i want to add these to Motion's permanent collection of content. Online help is surprisingly unhelpful as to how to do this: it always assumes I mean importing a file or two to use in a current project, but no; I want to have this stuff in Motion's permanent content collection. So... what's the right way to do that, all in one go? Please don't tell me I have to import each piece one at a time and re-save it.
Robin S. Kurz
Re: Importing new content to keep in Motion
on Oct 31, 2015 at 5:56:19 pm
I'm not aware of any way of adding objects to the Contents, but you can save anything (even individual layers, effects, groups etc. etc.) as a FAVORITE. In which case it will be permanently available form that folder. Or even the favorites MENU if you like.
- RK
____________________________________________________
Deutsch? Hier gibt es ein umfassendes FCP X Training für dich!
Matt Galuszewski
on Nov 1, 2015 at 1:46:44 am
I may be misunderstanding you but I have nothing to loose to tell you what I do when I have some mov and image files that I reuse all the time.
There are 2 ways;
Using finder
Create a folder in ~/Library/Application Support/ Motion/Library/Content
So if the client is CREATIVE COW create a folder for example ~/Library/Application Support/ Motion/Library/Content/Creative Cow.
Place the files in there and they immediately appear in motion in the Library Content folder.
Using motion
Import the files you want to use in to a new or existing project.
Drag the files or copy and paste them from the motion media window to the Library Content folder.
Robin S. Kurz
on Nov 1, 2015 at 1:43:55 pm
Interesting! Hadn't looked into this before. Nice tip. Whereby we're talking about the Library folder of YOUR USER. Unfortunately doesn't work globally via the main Library.
- RK
Matt Galuszewski
on Nov 1, 2015 at 7:11:38 pm
I have added content to the main Library folder using the finder method but it doesn't do a live update in Motion. Motion needs to be restarted after which the items appear in Motion's content folder.
I do recall however losing this content once when performing a motion update and then another time I didn't.
I think it's a lot safer to save in the User library folder.
