Auto orient?
COW Forums : Apple Motion
Bret Williams
Auto orient?
on Apr 28, 2015 at 8:37:10 pm
As I realize I'm still learning to do what I've known how to do in AE for years I have another question...
How do you auto-orient objects along a path? For example I have a car driving along a curvy path/road and I'd like it to always face the direction it's traveling, turning appropriately as the path turns. In AE it's called auto-orient along path.
Mark Spencer
Re: Auto orient?
on Apr 28, 2015 at 8:50:33 pm
Add the Align to Motion (Simulation) behavior.
Mark Spencer
Freelance Producer/Editor/Motion Graphics Artist
Apple-certified Master Trainer
Author, Motion 4 from Peachpit Press
http://www.applemotion.net
Bret Williams
Re: Auto orient?
on Apr 28, 2015 at 8:59:48 pm
Excellent I'm on the right path as I just figured that out (snap alignment to motion, correct?) EXCEPT, it turns my car 90degrees and it points the side of the car down the path. Perfectly sideways however. It seems to override the actual rotate controls. In AE, auto orient is similar to an "add" parameter. It orients it, but if you've adjusted the rotation yourself, it adds the info together.
Robin S. Kurz
Re: Auto orient?
on Apr 29, 2015 at 9:16:09 am
I'm assuming you have the rotation axis set to Z? But if you don't want to edit the graphic accordingly, then simply apply both behaviors to the group that the car is in and position, scale, rotate etc. as needed within the group.
- RK
____________________________________________________
Deutsch? Hier gibt es ein umfassendes FCP X Training für dich!
