Weird Motion Text Jump in Final Cut
COW Forums : Apple Motion
Jake Reeves
on Feb 16, 2015 at 4:52:09 pm
I'm just starting to teach myself Motion.
I'm linking to this little clip of the same motion file in a FC sequence. The second being over a slug with a negative filter on it. At the end of the text there is a bit of a jump where the text loses its glow. This doesn't happen in the first clip. Can someone tell me why this happens and what I can do to fix it, if there is a fix?
https://vimeo.com/119771592
Robin S. Kurz
Re: Weird Motion Text Jump in Final Cut
on Feb 17, 2015 at 9:59:37 am
It looks to me as if you also have an outline or shadow that is disappearing for whatever reason. You'll want to check those parameters and/or the keyframe editor. And I'd say the reason you're not seeing it with the first one is simply because the background is black.
- RK
____________________________________________________
Deutsch? Hier gibt es ein umfassendes FCP X Training für dich!
Jake Reeves
on Feb 17, 2015 at 3:17:36 pm
Robin,
That would make sense. I'm looking into that.
